Android devices should be able to access the Internet.
My Android devices (older Android 9 phone and an Android 11 tablet) lose access to the Internet after a couple of minutes after having established a wireless connection. I can connect to my WLAN and access whatever, but after a certain amount of time, the WLAN status will change to "Connected without Internet access".
I have no networkdevices between my clients and my ISP's router, no firewall, no nothing. I'm 99.99% sure this is caused by some domain being blocked by my Pihole, but I can't find anything which stands out in the query log. I assume it only drops the connection when the Androids can't reach some kind of service or status domain, which only runs on a unspecified interval or after an amount of data has been exchanged, and after failing to reach that, will simply disable Internet access.
Alright, thanks for the advice thus far. It indeed might be a blocklist I added in the past few months. It's just a shame that I can't seem to catch which domain this depends on. Or why this is even a thing... Google checking to make sure a device can load their advertisements, and cutting off Internet access if it can't, is absolutely bizarre to me.
