Recently I just ran pihole -r
and Reconfigure to update to the latest version of Pihole. After rebooting the RPi, the DNS resolution on the RPi fails and I cannot ping websites by their normal web address (pinging by IP address works)
Upon rebooting the RPi, ping google.com
should work as normal and return something like
64 bytes from lga34s13-in-f14.1e100.net (172.217.10.46): icmp_seq=1 ttl=54 time=19.8 ms
ping: google.com: Temporary failure in name resolution
Also when I try to run pihole -r
and either reconfigure or repair, when it gets to the part where FTL is installed, I get the following:
[✗] Downloading and Installing FTL Error: Unable to get latest release location from GitHub
Result of running dig google.com
pi@raspberrypi:~ $ dig google.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> google.com
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 16096
; EDNS: version: 0, flags:; udp: 1280
;google.com. IN A
;; Query time: 49 msec ;; SERVER: 127.0.0.1#53(127.0.0.1) ;; WHEN: Wed Jun 05 11:20:24 EDT 2019 ;; MSG SIZE rcvd: 39
Temporary fix:
I change the /etc/resolv.conf
name server from 127.0.0.1
to a public working DNS server for DNS resolution to work (like 8.8.8.8
). However I have to do this every single time after a reboot to get it working properly.
Afterwards i can ping google.com
and other websites as normal.
jmnn1hx3vi
Additional info:
Pihole version: v4.3
Raspbian GNU/Linux 9 (stretch)
PHP 7.0.33-0+deb9u3
