Continuing the discussion from Unblocking a single devices and FAQ How can I disable Pi-hole or unblock ads for a single device?
Provide a UI method to allow individual devices to bypass Pi-Hole.
This would only be possible if DHCP is turned on in Pi-hole, btw.
Yes, that is fine. At the moment I use a second AP, with a different DHCP range, with a non-Pi-hole DNS setup to achieve the same but I would rather manage it from one interface.
I realise I can make these changes manually but doing it from the interface is easier especially if running as a container in Docker.
Implemented in v5.0 with Group Management.
