All internet appears to be down for both pihole and clients
I'm using a raspberry pi 2 B that has been functioning perfectly for a few months at this point, it's running rasbian. It should be using unbound to resolve domains for clients and itself. This may be a problem with unbound or a larger problem with it's networking settings.
What it is actually doing is failing to use network services at all, I can't ssh in and when I connect a monitor and keyboard I can't update the system or ping anything due to a failure in "name resolution".
I can't paste one due to the lack of internet, but I'd be happy to as soon as I can get it running
This typically is a system level problem unrelated to Pi-hole. Pi-hole has no involvement in a ssh connection.
Do you still see the Pi on the network (router or network scanner will show this).
When you connect the monitor and keyboard, what does the following command show?
ip addr
It started working after I restarted unbound, so I'm not sure if that was it but it seems fine now
