Andsim
November 12, 2021, 12:16pm
1
The issue I am facing:
I am facing every day with my smart devices even Alexa having issues staying blue light for 60 sec
Details about my system:
I have two pihole in VMware running same time and using UDM PRO, one unfi switch 16 port and one wifi
Same pihole not resolving Alexa or other devices to work properly in day
Here is second pihole https://tricorder.pi-hole.net/CKneGaFu/
First pihole https://tricorder.pi-hole.net/ivRVeTdA/
jfb
November 12, 2021, 1:33pm
2
I would bet this list is blocking some of the Amazon domains. Disable this list and rebuild gravity and see if the problem resolves.
https://hostfiles.frogeye.fr/firstparty-trackers-hosts.txt
Andsim
November 12, 2021, 2:21pm
4
ty only have 24 hrs a time to see
Andsim
November 12, 2021, 9:57pm
5
it happen again this not fix
jfb
November 12, 2021, 9:58pm
6
Use these tools to determine what blocked domain is causing the problem, then whitelist the domain(s).
Block ads or fix broken sites
This FAQ is written in the context of finding out how to block an ad that isn't blocked automatically, but the same steps can be used to troubleshoot issues with sites that don't function properly. An example is that sometimes certain payment gateways try to collect metrics on the sale, but these domains are blocked by Pi-hole, so the payment cannot be processed. Also, some links send you through several referrers and if one of them is blocked, you may land on a …
Andsim
November 12, 2021, 10:18pm
7
was trying to pin the address
jfb
November 12, 2021, 10:53pm
8
Here is some additional info.
system
Closed
December 3, 2021, 10:53pm
9
