pihole should block ads
after a week of good work, in an startimg seeing as everwhere (even is site where before it was blocking them)
Please post the output of the following commands from the Pi terminal:
nslookup pi.hole
nslookup pi.hole 192.168.1.77
echo ">stats" | nc localhost 4711
And from the command terminal or command prompt on a connected client:
nslookup pi.hole
pi@raspberrypi:~ $ nslookup pi.hole
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: 192.168.1.77
pi@raspberrypi:~ $ echo ">stats" | nc localhost 4711
domains_being_blocked 116540
dns_queries_today 2241
ads_blocked_today 531
ads_percentage_today 23.694778
unique_domains 250
queries_forwarded 812
queries_cached 898
clients_ever_seen 10
unique_clients 6
dns_queries_all_types 2241
reply_NODATA 163
reply_NXDOMAIN 107
reply_CNAME 351
reply_IP 551
privacy_level 0
status enabled
---EOM---
did I answer you correctly? Thanks for replying to my post
Yes, but only for 2 of the 4 statements @jfb has posted.
So far, you are missing the output of the following command from the Pi terminal:
And another lookup on a terminal or command prompt from a connected client:
nslookup pi.hole
Based on the info you already posted, you can see that Pi-hole did successfully block 531 of 2,241 or roughly 24% of your DNS queries as undesirable. So from a technical perspective, Pi-hole seems to be working OK.
There could be several reasons why you have the impression you are seeing more ads. e.g. you still could have some stray clients that do not use Pi-hole as DNS server (which the above command from a connected client would reveal), or you are more frequently browsing sites that show ads whose domain is not on any of your blocklists (either because it never was or the site's ad provider changed or a blocklist doesn't include the site any more), or your browser is somehow configured to bypass Pi-hole, etc. etc.
Are you experiencing ads on all clients or specific clients only?
In the latter case, verify that your client indeed uses Pi-hole.
If you are seeing ads on all of your clients, verify as above and then try to find out what domain an ad comes from and whether it's included in your blocklists:
Thank you @Bucking_Horn. So by far, I keep seeing ads on my smartphone and I always see ads on youtube from any device (those ads are always 2 mins long and I can't skip them). I know that there is nothing much to be done with the ones on youtube. I will keep you updated.
