[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system
-hardware]
after rebooting the pi-hole's dnsmasq service is not running because port is in use error.
From your debug log, not necessarily related to your issue:
[i] dig return code: 0
[i] dig response: "Raspbian=10,11 Ubuntu=18,20,21,22 Debian=10,11 Fedora=34 CentOS=7,8 Rocky=8"
[✗] Distro: Ol
[✗] Error: Ol is not a supported distro (https://docs.pi-hole.net/main/prerequisites/)
What OS distribution are you running your Pi-hole on?
Your debug log shows dnsmasq to be active on yor system:
[✗] udp:192.168.122.1:53 is in use by dnsmasq (https://docs.pi-hole.net/main/prerequisites/#ports)
udp:0.0.0.0%virbr0:67 is in use by dnsmasq
[✗] tcp:192.168.122.1:53 is in use by dnsmasq (https://docs.pi-hole.net/main/prerequisites/#ports)
You'd need to uninstall or disable dnsmasq to free those required ports for pihole-FTL, Pi-hole's embedded dnsmasq variant.
Also, your router is distributing its own IP as DNS server:
* Received 300 bytes from virbr0:192.168.122.1
Offered IP address: 192.168.122.115
DHCP options:
Message type: DHCPOFFER (2)
router: 192.168.122.1
dns-server: 192.168.122.1
While that possibly would be a valid configuration (e.g. if your router would use Pi-hole as its upstream DNS resolver), it would be preferred if your router would distribute Pi-hole as local DNS server.
