After an hour, Pi Hole no longer issues IP Addresses (Latest v6)
IP Addresses to be issued using Pi Hole as the only DHCP server on the network of about 15 devices
So my set up is: Router with DNS set to Raspberry Pi DHCP is off at the router and activated on Pi Hole.
I have had the same set up running without issues for a few years now.
I upgraded from v5 to v6 and after a day or so decided a clean install would be best. I tend to do this when a major update comes out.
SD Card was formatted, OS installed, upgraded, Pi Hole installed and ready for me to configure it.
Basic configuration took place, such as a couple of block lists, DHCP activated and a couple of static IPs. All other settings were as per the install. I rebooted the Pi, signed in to the admin page, checked the Network tab and devices we listed. All good so far.
However an hour or so later my devices could no longer connect to the internet nor could I SSH into the Pi.
I’ve always had DHCP refresh at 5 min interval. I know this is over kill but never had an issue before.
When a device finally did connect the IP was a local IP and not one generated by Pi Hole. Rebooting the Pi didn’t solve the issue.
I decided to start again as I thought I’d missed something, clean install of the OS etc. don’t change any settings this time other than acting the DHCP server.
Again an hour or so later the same thing happened.
Anybody else having this issue on the latest version of Pi Hole?
Currently running a back up of v5 to remove ads and no issues at all.
https://tricorder.pi-hole.net/YMqfAeBH/
A DHCP server requires a static IP.
You don't mention having configured your OS to set a static IP address on the device that runs your Pi-hole.
If you didn't, your machine would have lost its IPv4 as soon as its DHCP lease as acquired through your router's DHCP server had expired, just as the rest of your router's DHCP clients.
Yes the Raspberry Pi has a static IP set within the OS.
