Ads show with a 5-10 seconds delay
Hi forum
when visiting the site wieistmeineip.de everything loosk good but ads appear about 5-10 seconds after the page loaded, although my pi-hole blocking is working fine.
Is there any chance for me to keep these ads blocked?
Ads should not show
https://tricorder.pi-hole.net/p7AIhfs2/
That usually means you have more than just Pi-hole as the DNS server for clients to use.
Thank you very much for your fast reply @DanSchaper
I am resoving DNS with pfSense and I am not using any other resolver or DNS server.
So I guess there might be another root cause?
Short update, I tested the site with Firefox, Brave and Chrome.
In Chrome the ads never show up, but in Firefox and Brave they do.
bump :face_with_peeking_eye:
Check that you haven't inadvertently enabled DNS over HTTPS in firefox.
If it is set to anything other than "OFF" in Settings -> Privacy and Security -> DNS over HTTPS, then firefox will try to go around your network's DNS.
I gather brave has a similar option to explore.
Thank you for your comment @robgill , I have checked my firefox seeting but it seems all has been tunred off
So I guess there must be anyother reason.
I am also wondering why the ads show up quite late. It takes about 6-7 seconds after the page fully loaded.
