Ads on most sites not blocked, Blacklisting not working
50% or more ads should be blocked across most sites
Blacklisted sites will no longer be reachable
50% or more ads blocked only on very small, select number of sites
Blacklisted sites are still reachable
https://tricorder.pi-hole.net/7d1ctows7s
##Notes and Comments:
Seemingly all ads on most sites are still displayed. Ads on speedtest.net are fully blocked which is nice, and most banner ads (provided their not a video) are blocked on YouTube, and if I click on an ad on bing or so it won't load which is nice, but it doesn't seem to work anywhere else. Ads on kissanime or watchcartoononline still appear in their entirety, as well as seemingly every other site I regularly visit. I get that embedded ads can't be blocked, but these aren't embedded ads from what I can tell.
I have been unable to block sites, even when I put them on the Blacklist. For example, I put bing.com into the Blacklist and select either add(exact) or add(wildcard), but nothing happens if I then go to bing; i.e. I am still able to reach and use bing.
What kind of client are you using for browsing? If your client has more than just the Pi-hole DNS server listed then you will get ads in via the other DNS servers. There is no such thing as primary/secondary or fallback DNS, only Pi-hole DNS should be used.
Your blacklist only has one domain on it. It looks like you are trying to blacklist https://www.bing.com and that is not quite correct. Only www.bing.com is a domain, and www.bing.com/site is also incorrect.
How are you adding sites to the blacklist? Post a screen capture of the screen where you are entering a domain on the blacklist (you can paste a screen capture into the reply).
