Ads not blocked on some clients
Hello.
I finally managed to install Pihle.
Unfortunately, it doesn't seem to be working properly. Everything is displayed correctly in Recent Queries.2020-05-07_13-18-59|612x500
Unfortunately, Pihole will also release ads.
I tried: restart Pihole, restart PC, ipconfig / flushdns, clear DNS cache in the browser.
I test ads on speedtest.net. Where do you test ads?
Why am I still seeing ads? Can you please advise?!
[Replace this text with what you think should be happening]
I apologize for my previous vague question. Perhaps it will help more:
I think Pihole should prevent advertising on websites like speedtest.net.
Currently, Pihole receives all DNS queries from my devices, but does not block any advertising.
https://tricorder.pi-hole.net/e4a76865f0
It helped? Can you please advise me why it doesn't work?
Your debug log shows that Pi-hole is receiving DNS queries and blocking per your blocklists.
   [2020-05-07 13:20:17.140 10963] Imported 51106 queries from the long-term database
   [2020-05-07 13:20:17.142 10963]  -> Total DNS queries: 51106
   [2020-05-07 13:20:17.142 10963]  -> Cached DNS queries: 21178
   [2020-05-07 13:20:17.142 10963]  -> Forwarded DNS queries: 23123
   [2020-05-07 13:20:17.142 10963]  -> Exactly blocked DNS queries: 6805
   [2020-05-07 13:20:17.142 10963]  -> Unknown DNS queries: 0
   [2020-05-07 13:20:17.143 10963]  -> Unique domains: 2122
   [2020-05-07 13:20:17.143 10963]  -> Unique clients: 10
   [2020-05-07 13:20:17.143 10963]  -> Known forward destinations: 2
If you are seeing ads, it is likely that that (or those) clients have an alternate DNS server available to them.
From the client on which you see ads on speedtest.net, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup pi.hole 192.168.1.11
Thank you for answer. Output:
Server: cc74c245ce78
Address: 192.168.1.11
And this one?
Same result:
nslookup pi.hole
That client is using Pi-hole for DNS, but the browser might not be. Use these tools and see if you are seeing all the DNS traffic from that browser in Pi-hole:
I'll look into it, but now I've found an interesting thing: On a virtual PC that has never been connected to the Internet, ads aren't showing. On 5 home phones (android) and laptops and PCs (windows + firefox), the ads are still displayed, even if I manually entered the IP address of the pihole.
From one of these PC's, what is the output of ipconfig /all
I don't think there's a mistake:
ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Vejv-cz_PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 3:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-ProtonVPN Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-B6-F0-03-14
Ethernet adapter VirtualBox Host-Only Network:
   Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
   Physical Address. . . . . . . . . : 0A-00-27-00-00-06
   DHCP Enabled. . . . . . . . . . . : No
   Link-local IPv6 Address . . . . . : fe80::193f:2cd9:3309:eabc%6(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.234.188(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 269090855
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-26-2C-67-A5-00-E0-4C-68-21-09
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter Ethernet 5:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9 for OpenVPN Connect
   Physical Address. . . . . . . . . : 00-FF-B8-77-C3-BE
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection
   Physical Address. . . . . . . . . : B4-2E-99-32-0A-E0
   Link-local IPv6 Address . . . . . : fe80::b1cc:8d58:a947:9db6%3(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.51(Preferred)
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 800337561
   DNS Servers . . . . . . . . . . . : 192.168.1.11
Ethernet adapter Ethernet 2:
   Description . . . . . . . . . . . : Windscribe VPN
   Physical Address. . . . . . . . . : 00-FF-27-85-43-4F
Ethernet adapter Síťové připojení Bluetooth:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 00-1A-7D-DA-71-13
Maybe ads are leaking through the IPv6 DNS server(s) configured on the Win client:
netsh interface ipv4 show dnsservers
netsh interface ipv6 show dnsservers
Or the DNS answers coming from the DNS server(s) might be malformed/protected by some AV software:
