Ads not being blocked in apps
Ads being blocked not only in browsers but in apps too.
Since updating Pi-hole to V4.3.1, I've noticed that ads are showing in apps that were previously blocked.
I know that it's difficult to block ads if served from the same domain but I think in this case, I'm not sure if the ads would be served via a CDN or via the server on which the app pulls its data anyway.
Either way, I've noticed that ads that were previously blocked are now showing in apps.
https://tricorder.pi-hole.net/0v9yph9dil
You haven't provided any specifics on which OS, which apps, etc. The update to Pi-Hole should not have changed this behavior, since the functionality of ad-blocking is the same.
These tools can help you determine the source of ads.
