Ads aren't blocked on Pi-hole 5.0
Equipment:
-Raspberry Pi 4 using wifi
-Pi-hole 5.0
-Technicolor TG799vac router with Mint 17.2, https://bc.whirlpool.net.au/bc/hardware/?action=h_view&model_id=1622
-Windows 10 desktop using ethernet
I can't seem to get Pi-hole to block any ads at all on any device.
I had Pi-hole v4 earlier but now it's 5.0. I have a weekly updating script set on my Raspberry. I've set my routers DHCP server to use my Raspberry's ip 192.168.1.142 as it's DNS.
On my Windows 10 machine running following commands:
C:\
λ ipconfig -all
Ethernet adapter Ethernet 2:
   Connection-specific DNS Suffix  . : lan
   Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection #2
   Physical Address. . . . . . . . . : 04-D9-F5-F4-1C-43
   IPv4 Address. . . . . . . . . . . : 192.168.1.151(Preferred)
   Lease Obtained. . . . . . . . . . : tiistai 7. heinäkuuta 2020 17.16.26
   Lease Expires . . . . . . . . . . : tiistai 7. heinäkuuta 2020 18.16.26
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DNS Servers . . . . . . . . . . . : 192.168.1.142
C:\
λ nslookup pi.hole
Server:  limppu
Address:  192.168.1.142
It shows 192.168.1.142 as DNS Servers . Should the DCHP Server be that too?
I can access both http://pi.hole and http://192.168.1.142/admin on any client and getting queries to the log. Tested on desktop with ethernet and android device with wifi.
Debug token:
https://tricorder.pi-hole.net/6ow5o5yz9x
Now I'm doubting whether even v4 worked at all since I always use Firefox with uBlock :D.
From your Windows client, what's the output of the following commands:
nslookup pi.hole
nslookup flurry.com 192.168.1.142
C:\
λ nslookup pi.hole
Server:  limppu
C:\
λ nslookup flurry.com 192.168.1.142
Server:  limppu
Non-authoritative answer:
Addresses:  98.136.103.26
          74.6.136.153
          212.82.100.153
Forgot to mention I also disabled IPv6 because I found some thread saying it could help. It doesn't.
You have your privacy level set to 4. In Pi-hole V5 (due to the nature of the gravity database), this results in no ad-blocking. Known issue.
  [2020-07-07 17:08:22.739 17524] Notice: Increasing privacy level from 0 to 4
  [2020-07-07 17:08:22.739 17524]    PRIVACYLEVEL: Set to 4
Change your privacy level to 3 or lower and the problem will resolve.
https://github.com/pi-hole/FTL/issues/755
Seems to be working now. Is the following correct now then?
C:\
Server:  limppu
Addresses:  ::
          0.0.0.0
Tried https://canyoublockit.com/ extreme test and various other sites with Edge and Chrome without ad blockers and (almost) everything was blocked. Thanks :).
Yes. That is properly blocked.
