Instead of disabling Apache2, I just set the lighttpd server to use another port in the /etc/lighttpd/lighttpd.conf file. Solved! I can now use both apache2 and pihole.
You are probably missing the PHP support (for Apache) if you pages are rendering as text only.
Can you upload a debug log so we can take a look ?
You can move lighttpd to a different port and it will co-exist with Apache. The setting is in /etc/lighttpd/lighttpd.conf .
Note that your local changes will be overwritten with a Pi-Hole repair or update.
Thanks RamSet. Here is a debug log: https://tricorder.pi-hole.net/lcdfi1qifv
You have 2 options ![]()
- you can install the (missing?) php support for apache
- you can edit
and change theserver.port = 80to some other port of your choice.
This will make the /admin/ interface available via http://pi-hole:PORT/admin/
2 is more of a workaround and not the most optimal thing for your raspberry, as you have all those resource intensive things there too.
YAY!
I got it to work!
The lighttpd was located unter /etc/lighttpd/lighttpd.conf
I changed the port to 88 and when I accessed pihole:88/admin, it worked!
Thank you all so much for your suggestions!
Good idea to install php for my apache too. I will look into it!
