Admin interface not reachable
Hey guys
Unfortunately I can't reach the web interface, using curl -I 127.0.0.1 on the Pi 3b it doesn't show with the X-Cross.
HTTP/1.1 200 OK
Content-Type: text/html; charset=utf-8
Accept-Ranges: bytes
ETag: "857202276"
Last-Modified: Mon, 10 Aug 2020 14:08:54 GMT
Expires: Wed, 14 Oct 2020 06:25:00 GMT
Cache-Control: max-age=0
Content-Length: 10701
Date: Wed, 14 Oct 2020 06:25:00 GMT
Server: lighttpd/1.4.53
The Browser tell me
http://192.168.179.2/admin/ The website is not available
But I can reach another webserver on port 8081/8082 (ioBroker).
Ipv4 was made using FritzBox Static and was also static during the installation of PiHole.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.179.1
   * Pinging 192.168.179.1...
ping: Warning: source address might be selected on device other than eth0.
Interesting side effect of the auto configuration, he configured the Br0 interface
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.179.2  netmask 255.255.255.0  broadcast 192.168.179.255
        inet6 fe80::ba27:ebff:fe0f:8a1d  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:0f:8a:1d  txqueuelen 1000  (Ethernet)
        RX packets 5831  bytes 1843101 (1.7 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5874  bytes 470792 (459.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
https://tricorder.pi-hole.net/a24c3t8k6c
