Admin dashboard not displaying metrics
Expected Behavior:
Dashboard should display metrics. Currently, no metrics displayed with or without clients assigned.
  • Bookworm
  • RPi 5
Actual Behavior:
I'm able to login to the Pi-hole admin dashboard, but no metrics are displayed. Dual arrows rotating in circle animation displayed only. RPi host does display dynamic q/min, cpu, and ram metrics. If I point a client to the server, the q/min will react, same as when I stop queries.
https://tricorder.pi-hole.net/Km1hsY8o
Here's a snapshot of the dashboard.
Do you see any error messages in the browser Console (devtools)?
Do you see the same if you use a different browser or access from a different device?
devtool_errors.txt (1.6 KB)
Please see attached txt for devtools errors from Firefox.
I didn't even think to use another browser (rookie mistake). Typically, I use Firefox, and that is the browser giving me trouble. However, I just logged in to the dashboard on Edge, and everything seems to work normal. Nevertheless, I attached the error output from Firefox devtools.
Try to clear Firefox cache and try again.
Cleared all cache data including history, still not working properly. One thing I forgot to mention, if I navigate the internal features, such as the clients list, no information is displayed. However, standard website formatting is not affected. Basically, it seems like the server is up and running, but not actively populating data to the browser (with the exception of the host metrics in the top left corner).
Also, Pi and Firefox browser are up to date.
