Admin Console shows loading symbols and does not work properly
The Admin Console should show anything else than loading symbols and blacklisting etc. should work.
The Admin Console shows only loading symbols on the dashboard and no numbers in the fields at the top. When trying to blacklist (or whitelist) a domain, it says "Failure! Something went wrong, see output below:" but shows no output. When clicking on "Network" a popup message "An unknown error occured while loading the data." occurs. Same applies for "Query Log". Ad-blocking however seems to work properly and new blocklists can be imported without issues.
https://tricorder.pi-hole.net/61tm9ohd7v
[✓] CentOS Linux 8 (Core)
Centos 8 is not a supported OS. There are some known workarounds:
Ah, if everything could be so easy. Works fine now, many thanks!
