maxpd1
December 18, 2022, 5:17am
1
I wondered why https://www.ebay-kleinanzeigen.de/ is still showing tons of ads.
I identified the domain https://admarkt.ebay-kleinanzeigen.de as the problem.
But I couldn't found it in any blocklist.
Q1: Is this a necessary domain?
Q2: How do I put it bymyself into a blocklist as it isn't appearing in the QueryLog.
Regards
maxpd
jfb
December 18, 2022, 5:21am
2
This is a URL. The domain is admarkt.ebay-kleinanzeigen.de.
If the domain isn't showing in the query log, then Pi-hole can't block it for the requesting client.
But, if you want it blocked add the domain to your blacklist anyway - in the domains tab.
maxpd1
December 19, 2022, 11:47am
3
Thank you for explanation.
But doing this I still see the ads from admarkt.ebay-kleinanzeigen.de
jfb
December 20, 2022, 1:01am
4
The ads must be coming from a different domain. If you block a domain with Pi-hole, the domain won't resolve to an IP and a client cannot load the content from that domain.
Use these tools to pinpoint the source of the ads:
Block ads or fix broken sites
This FAQ is written in the context of finding out how to block an ad that isn't blocked automatically, but the same steps can be used to troubleshoot issues with sites that don't function properly. An example is that sometimes certain payment gateways try to collect metrics on the sale, but these domains are blocked by Pi-hole, so the payment cannot be processed. Also, some links send you through several referrers and if one of them is blocked, you may land on a b…
