whole
December 23, 2020, 7:45am
1
Not really an issue just an observation.
I am using this highly recommended list:
Only issue I notice is that every single time I run 'pihole -g'
I get '[β] Status: Retrieval successful ' even though there were no updates to the list, it re-downloades the list again,
5 minutes later same thing it doesn't see the it is the same exact list as 5 minutes ago.
I assume it is unique to all lists hosted at
https://raw.githubusercontent.com/
Another example was
'https://raw.githubusercontent.com/blocklistproject/Lists/master/abuse.txt '
which is huge 500k list
but thenI found they have an alternative link
https://blocklistproject.github.io/Lists/abuse.txt
and now I get
[β] Status: No changes detected
which is expected if there were no updates.
This is a known issue. Github does not provide the necessary http header of "last modified" so pihole will always download it and process as if changes occured.
For further details:
I've noticed that (most of) my adlists get the status Status: Retrieval successful instead of No changes detected when running pihole -g, even when running it twice within a minute.
Looking at the code, I see that the ''Status' is based on HTTP response.
The code even states that some servers don't provide the necessary header
As pihole will save all downloaded lists locally, I request to compare old local list and (new) downloaded to decide if "Status" should be "changed" or "not changedβ¦
whole
December 24, 2020, 1:19am
3
Thanks for the explanation,
So github won't let you know about "last modified"
Why do you think 'github.io ' seems to be providing the response
seems to be doing that
No real need for that list. It's rarely updated and it's run by unscrupulous individuals that have tried to sell Pi-hole as a commercial product in the past.
system
Closed
December 31, 2020, 3:44am
6
