The way it works in the current version (4.0) is that excluded domains aren't shown in the top lists (top permitted domains or top blocked domains). Similar for excluded clients.
Will this be changed in a new version? Because about 200K of the blocks is just one domain.
Or is there something that I can do to block the requests from being logged in the first place? I cant stop it on the host device because its a security camera.
On some IOT devices you can specify the DNS to use. May not be the case for your camera, but worth a check.
If you use your Pi-Hole as DHCP server, you can selectively exclude clients by MAC address and assign them to a different DNS server. It is done in one of the dnsmasq configuration files:
I am using pfsense and forcing DHCP clients to the Pi-Hole DNS server.
You helped reminded me that here is a way to tell each static client to use a certain DNS server. So I forced the Cameras to use pfsense DNS and then I made an DNS entry to 0.0.0.0 in the DNS Resolver for --www.nwsvr1.com-- .
