The issue I am facing:
Hi, I want to run two pi-holes on two different subnets. These subnets will be connected using a site2site VPN. This means, that we're goint over a gateway so identifying a client by it's mac-address isn't possible.
Unfortunally pihole adds clients by their mac-address by default instead of using the ip-address.
I understand it because ip addresses can change but in my case it results in:
So the pihole on site2 will only see the vpn-gateway's mac-adress, which doesn't match with this client. Rules behind the groups the client is assigned to will be not considered.
Of course I can add an IP-Adress of this client but manualy but I want to have the nice little hostname behind it (see screenshot) as the comment-field is used only for the interface name in my system.
Is there an option to add a client by ip-adress WITH hostname description behind when it's (at the moment) in the same network as pihole (so if pihole has the mac-address)?
Details about my system:
pihole <---> site1 <---- VPN ----> site2 <---> pihole
clients <-┘ └-> clients
Setting up ULA and custom conditional forwarding
