Add 'number of domains' column to Adlist group management
It would be useful to have in the List of configured adlists a column with the number (quantity) of domains (and size?) added by every list.
Now the columns are: Address | Status | Comment | Group assignment | Action
The number of domains would help in finding a excessively big list or an empty one.
Regards!
At the moment you see the number of domains if you run a gravity update (pihole -g) or via the web interface. But likely there will be more information in the webinterface in the future:
https://github.com/pi-hole/AdminLTE/pull/1673
I'll mark this as implemented in Pi-hole web V5.5.
