hello guys i am using alot this website aeternum-map.th.gl/ . but it is causing me problems. a popup that says adblock detected makes it unusable. is there a way i can prevent that?
you can always whitelist the domain and see if that resolves your issue.
I use https://www.newworld-map.com/ without problems
