Ad lists storage location in database
May be off topic, but I used to backup the adlist files as part of a script. Since these files aren't being used any more, anybody got a good reference for where this info is stored now? Is it good enough to save the gravity.db file? Or do I need to extract all of this from the gravity database now and use that for restoring?
The database contains all URLs of the adlists, the downloaded domains + everything of the group management. If you're just interested in the adlist URLs it would be overkill to save the whole database. You can export the adlist information via SQL.
