Ad Block for Sky Stream Puck (UK)?
I've just got a Sky Stream Puck and wondered if anyone has managed to block the ADs ? I've tried the regex entry "(.|^)skyadsmart.com$" that I saw in Reddit but that's not working on Sky Stream.
Thanks
If Sky Stream uses separate domains for adverts then you will be able to track them down using your Query Log or browser add-ons.
Yes, I've used the logs on different catch up services in the past, but the Sky device is very chatty, so I just wondered if anyone has solved it before I re-invent the whole discovery process,
Good luck, yes it can be a painful process for very chatty devices, and may not even be possible depending on how they've implemented adverts. Pi-hole has limited support for Adblock Plus style lists now too, and since ABP is a well-supported extension, perhaps there is an ABP list out there you can find and use in Pi-hole.
Edit - limited support for ABP, ref @jfb comment below
Pi-hole has very limited support for adBlock style lists. We only import a very narrow category of wildcard blocks.
Thanks for the replies, I've been doing a bit of tracking today and one DNS query that keeps coming up at the start of playing a TV show is "hsar1012-soip-ads-prd.cdn01.skycdp.com", I've added this to the blacklist & also via regex but somehow it does not get blocked.
Here's a snip from the log (pihole -t), sorry I'm not sure how to add code here so I've edited the chevrons from CNAME.
Jun 1 17:00:24: query[A] hsar1071-soip-ads-prd.cdn01.skycdp.com from 192.168.0.205
Jun 1 17:00:24: forwarded hsar1071-soip-ads-prd.cdn01.skycdp.com to 1.0.0.1
Jun 1 17:00:24: query[AAAA] hsar1071-soip-ads-prd.cdn01.skycdp.com from 192.168.0.205
Jun 1 17:00:24: reply hsar1071-soip-ads-prd.cdn01.skycdp.com is CNAME
Jun 1 17:00:24: reply hsar1071-soip-ads-prd.cdn01.skycdp.com.edgesuite.net is CNAME
Tools > Generate Debug Log
Using the formatting tools in the reply window, format the block of text as "pre-formatted text". You can also do this from the keyboard with the ` character.
put the character three times ``` at the start and end of the text - the line before and the line after
Is this what you mean?
I've changed a few things since my last post so can run it again if needed..
https://tricorder.pi-hole.net/Ex41EqRP/
To format an inline code, you need to enclose the text with backticks, like this:
`text displayed as code` will be shown as: text displayed as code
To format a block of code, you just need to add "fences" (3 backticks), before and after the block:
code block
Will be rendered as:
code block
You can select the text and use the image button on toolbar to format code.
You can also simply select the text and press CTRL+E.
