Hi there,
I have pi-hole an a RBPi zero w running (including an ethernet-adapter > LAN-connection) and just installed PiVPN/Wireguard. This worked pretty good. Pi-Hole is still running, everything's fine so far...
Now I'm struggling with finding the IPv6-address which I need to enter on the port in my router? I only find a IPv6 address with 6 chapters, but I need 8.
Can you assist or is the problem related to the RBPi zero? Thanks
