The issue I am facing:
Unable to connect to pi-hole docker container from another container without first allowing port 53 on host.
Details about my system:
I have Pi-Hole running in a Docker container using the following docker-compose:
version: "2"
services:
pi-hole:
container_name: pi-hole
image: pihole/pihole:latest
restart: unless-stopped
volumes:
- /volume1/docker/pi-hole/etc/dnsmasq.d:/etc/dnsmasq.d
- /volume1/docker/pi-hole/etc/pihole:/etc/pihole
ports:
- "443/tcp"
- "53/tcp"
- "53/udp"
- "67/udp"
- "80/tcp"
environment:
- ServerIP=192.168.2.4
- DNS1='192.168.2.3#5054'
- DNS2=''
- IPv6=false
- DNSMASQ_LISTENING=local
networks:
macvlan_private:
ipv4_address: 192.168.2.4
bridge_to_nas:
ipv4_address: 192.168.20.4
hostname: pi-hole
dns:
- 127.0.0.1
- 1.0.0.2
cap_add:
- NET_ADMIN
networks:
macvlan_private:
external: true
bridge_to_nas:
external: true
There is a macvlan network to avoid port conflicts when other devices try to access Pi-Hole, and a bridge network to allow the host machine to also use the Pi-Hole container as a DNS.
My understanding is that by using a bridge network, other docker containers should be able to access the Pi-Hole. However, using the following example docker-compose for another container, this doesn't quite work:
version: "2.1"
services:
freshrss:
image: linuxserver/freshrss
container_name: freshrss
environment:
- PUID=1026
- PGID=100
- TZ=America/New_York
volumes:
- /volume1/docker/freshrss:/config
networks:
- bridge_to_nas
dns:
- 192.168.20.4
hostname: freshrss
networks:
bridge_to_nas:
external: true
The two containers are on the same bridge network, however the RSS container is only able to access the pi-hole container when I make a firewall exception for port 53 on the host machine.
Is this the correct behavior? I would have thought this would not be necessary since they should both be on the same bridge network.
