About updateGravity problem
When i run "pihole updateGravity", i took an error.
(a.b.c.d is my forward dns)
log;
 [i] Target: ransomwaretracker.abuse.ch (TL_C2_DOMBL.txt)
  [✗] Status: ransomwaretracker.abuse.ch is blocked by https://smokingwheels.github.io/Pi-hole/allhosts. Using DNS on a.b.c.d to download https://ransomwaretracker.abuse.ch/downloads/TL_C2_DOMBL.txt
  • What is the purpose of smokingwheels.github.io/Pi-hole/allhosts address?
  • Why is ransomwaretracker blocked by smokingwheels.github.io/Pi-hole/allhosts ? What does this log mean ?
  • Should i remove ransomwaretracker address from adlist.txt ? Do you advice me ?
  • What can i do ? What is your suggestions ?
Thank you
This is not an error. Pi-Hole is informing you that since the domain that serves your requested blocklist is blocked by one of your other blocklists, it is bypassing itself to load the blocklist.
In the past, if a blocklist contained the domains of one or more of your other blocklists, you would not be able to download the blocklist without whitelisting its domain. Since it is clear that you want to load a blocklist if you have it in your blocklist subscriptions, this new feature was added to Pi-Hole a few versions ago.
In your case, the subscribed blocklist https://smokingwheels.github.io/Pi-hole/allhosts is blocking gthe domain ransomwaretracker.abuse.ch.
Pi-Hole went directly to your upstream DNS server to load the blocklist, bypassing itself.
You would need to contact the list maintainer to determine why this domain is blocked.
You do not need to take any action. Pi-Hole resolves the conflict for you with no action required.
Here is the code if you are interested:
