root@johnywalker:/var/log# pihole -v
Pi-hole version is v4.3.2 (Latest: v4.3.2)
AdminLTE version is v4.3.2 (Latest: v4.3.2)
FTL version is v4.3.1 (Latest: v4.3.1)
more /etc/cron.d/pihole
Pi-hole: Grab local version and branch every 10 minutes
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local > /var/log/see.log
jfb thank you.
can I ask one more question.
I am so sorry for my question.
Pi-hole: Grab remote version every 24 hours
35 18 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
But i can not understand two line.
pihole update checker local tested my version ? is it true ?
pihole updatechecker local read ;
root@johnywalker:/var/log# more /etc/pihole/localbranches
master master master
root@johnywalker:/var/log# more /etc/pihole/localversions
v4.3.2-0-ge41c4b5 v4.3.2-0-g38d8e77 v4.3.1
if my version is old,what did pihole do ?
Does automatic update? is pihole tell me ? Which ?
If there is an update then the web interface will note that in the version display. pihole -v will also note that there is an update available. Pi-hole does not auto update since that is a very bad thing to do.
As noted, there is no automatic update feature. You should read the release notes for a new version and then decide if you want to install it, then the update is manual with pihole -up
When there is a newer version available, then the version information at the bottom of the dashboard turns red to alert you that there is a newer version. There are generally also release announcements from the developers on this site, GitHub and Reddit.
