I am inquire about pi-hole will work on librem 5 ?
I did preorder smartphone is librem 5.
But wonder it will work?
Check out
Pi-hole works like any other DNS server.
Not familiar at all with the OS on that device, but unless they use an unknown, brand new, unique and proprietary way way of resolving the domain names, then, as long as you can set the DNS parameters to it, Pi-hole will work without any problems.
True while I get that smart phone that I will test and will report if it work as well also not only pi-hole will test on phone. Because some person complain that pi-hole cannot be in most smart phone. So this smartphone are may worth for project too.
