A few Arch Linux specific questions/issues
Arch Linux 64bit.
Pi-hole Version 3.3 Web Interface Version 3.2.1 FTL Version v2.13.1
Debug, status and blacklist should work as anticipated.
There doesn't seem to be any debug option in the Arch (AUR) package; you can run FTL in debug mode but it requires killing pi-hole service. There is no "pihole -d" option or "debug" from CLI.
Admin console (web) shows that Status is unknown, though pihole status shows everything is enabled. It shows unknown no matter what. Clicking enable fixes it, until a page refresh.
I cannot add domains to blacklist - it says "Failure! Something went wrong." in red; but as I can't debug normally I don't know why it's happening.
I cannot create a debug token - unless that's the same as the API token?
The arch package is maintained by some other community members, not someone on the Pi-hole dev team: https://aur.archlinux.org/packages/pi-hole-server/
Yeah, I knew that - I thought there might be someone else here dealing with similar. I'll talk to them.
Thanks
