I have successfully installed pihole on my server running Ubuntu, it has more than enough hardware for the requirements. It is not running through docker, but I have no access to the web ui I keep getting a 403 forbidden error.
I am reaching a 403 forbidden error when trying to access the web ui at /admin, or any of the other urls like pi.hole/admin:80
You have configured Pi-hole's webserver to listen on ports 80 and 443:
[webserver]
port = "80o,443os,[::]:80o,[::]:443os"
However, you are already running a separate webserver (lighttpd) on port 80:
udp:0.0.0.0:39520 is in use by avahi-daemon
udp:172.20.0.1:39555 is in use by Plex
udp:0.0.0.0:41641 is in use by tailscaled
[✓] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:123 is in use by pihole-FTL
udp:0.0.0.0:5353 is in use by avahi-daemon
udp:192.168.0.104:55142 is in use by Plex
udp:[::]:57398 is in use by avahi-daemon
udp:[::]:41641 is in use by tailscaled
[✓] udp:[::]:53 is in use by pihole-FTL
udp:[::]:123 is in use by pihole-FTL
udp:[::]:5353 is in use by avahi-daemon
tcp:127.0.0.1:45333 is in use by containerd
tcp:0.0.0.0:8191 is in use by docker-proxy
[✓] tcp:0.0.0.0:443 is in use by pihole-FTL
tcp:0.0.0.0:22 is in use by systemd
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
[✗] tcp:0.0.0.0:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
tcp:127.0.0.1:40151 is in use by Plex
tcp:127.0.0.1:631 is in use by cupsd
tcp:100.95.94.80:37297 is in use by tailscaled
tcp:[::]:8191 is in use by docker-proxy
tcp:*:7878 is in use by Radarr
tcp:[::1]:3350 is in use by xrdp-sesman
[✓] tcp:[::]:443 is in use by pihole-FTL
tcp:[::]:22 is in use by systemd
[✓] tcp:[::]:53 is in use by pihole-FTL
[✗] tcp:[::]:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
tcp:*:3389 is in use by xrdp
tcp:*:3390 is in use by gnome-remote-de
tcp:[fd7a:115c:a1e0::d701:5e54]:54802 is in use by tailscaled
tcp:[::1]:631 is in use by cupsd
tcp:*:32400 is in use by Plex
tcp:*:9696 is in use by Prowlarr
tcp:*:8989 is in use by Sonarr
To avoid that conflict over port 80, you'd have to configure either lighttpd or Pi-hole to use another port for HTTP access.
E.g. if ports 8088 and 8443 would be free, you could try to reconfigure Pi-hole via CLI:
I added lighttpd due to suggestions when I was looking into troubleshooting, that got me from 404 not found to 403 forbidden. I did your recommended port switch still, and will check when I get back on the same network as my server. I am currently having trouble reaching it remotely so I am not sure if that worked yet.
