T-z3P
October 27, 2019, 9:52pm
1
Web interface being accessible
I've been forced to completely remove my Apache2 install and reinstall it. Also tried with nginx and lighttpd. Receiving a "403 - Forbidden" error when trying to access the web interface. I've also tried to reconfigure PiHole with pihole -r, but the issue is still there.
curl -I http://127.0.0.1/admin
HTTP/1.1 301 Moved Permanently
Date: Sun, 27 Oct 2019 21:40:58 GMT
Server: lighttpd/1.4.45
https://tricorder.pi-hole.net/y0uu7pscw6
Have you run the uninstall script and can you provide the output from curl -I http://127.0.0.1/admin/
T-z3P
October 28, 2019, 2:35pm
6
I've just uninstalled now Pihole using 'pihole uninstall'.
HTTP/1.1 404 Not Found
Content-Type: text/html
Content-Length: 345
Date: Mon, 28 Oct 2019 09:26:18 GMT
T-z3P
October 28, 2019, 4:16pm
7
I've solved the issue.
I've ran the below, reinstalled and it's now working.
sudo rm -rf /etc/.pihole /etc/pihole /opt/pihole /usr/bin/pihole-FTL /usr/local/bin/pihole /var/www/html/admin
If anyone comes across this as a solution make sure you back up your existing settings as the above command will remove everything.
system
Closed
November 18, 2019, 4:54pm
9
