I'm using the latest docker image of the official pi-hole docker image (pihole/pihole:latest), according to my docker, this has the sha256 tag 8bc45afe1625487aef62859a5bf02f3d7b3429e480f4e29e4689635ab86ec312.
When I attempt to access the webUI through %host%:33435 (If that's not the default, I'm using the environment variable WEB_PORT to change it to 33435), I get the HTTP error 403 Forbidden.
I've tried clearing out my volumes which are tied to /etc/pihole and /etc/dnsmasq.d inside the container. I've also tried rolling back to tag 2023.05.1 and 2023.05.0, no change in outcome.
I'm running it as a service on a docker swarm, with a NFS attached storage for holding the volumes' data, but that shouldn't make that much of a difference.
I'm not sure if this will help, but this is the printout I get when inspecting the container:
"Id": "sha256:927e9854247157c40259b84b60d3e774283ba12fc91ea0feab86536320deebb1",
"RepoTags": [
"pihole/pihole:latest"
"RepoDigests": [
"pihole/pihole@sha256:8bc45afe1625487aef62859a5bf02f3d7b3429e480f4e29e4689635ab86ec312"
"Parent": "",
"Comment": "buildkit.dockerfile.v0",
"Created": "2023-05-30T18:53:35.471121075Z",
"Container": "",
"ContainerConfig": {
"Hostname": "",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": null,
"Cmd": null,
"Image": "",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": null,
"OnBuild": null,
"Labels": null
"DockerVersion": "",
"Author": "",
"Config": {
"Hostname": "",
"Domainname": "",
"User": "",
"ExposedPorts": {
"53/tcp": {},
"53/udp": {},
"67/udp": {},
"80/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"PATH=/opt/pihole:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"phpver=php",
"PHP_ERROR_LOG=/var/log/lighttpd/error-pihole.log",
"IPv6=True",
"S6_KEEP_ENV=1",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0",
"FTLCONF_LOCAL_IPV4=0.0.0.0",
"FTL_CMD=no-daemon",
"DNSMASQ_USER=pihole"
"Cmd": null,
"Healthcheck": {
"Test": [
"CMD-SHELL",
"dig +short +norecurse +retry=0 @127.0.0.1 pi.hole || exit 1"
"Image": "",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": [
"/s6-init"
"OnBuild": null,
"Labels": {
"org.opencontainers.image.created": "2023-05-30T18:51:05.660Z",
"org.opencontainers.image.description": "Pi-hole in a docker container",
"org.opencontainers.image.licenses": "",
"org.opencontainers.image.revision": "37bd3d2f0f9321211d9370fc96b7d06325cee887",
"org.opencontainers.image.source": "https://github.com/pi-hole/docker-pi-hole",
"org.opencontainers.image.title": "docker-pi-hole",
"org.opencontainers.image.url": "https://github.com/pi-hole/docker-pi-hole",
"org.opencontainers.image.version": "2023.05.2"
"Shell": [
"/bin/bash",
"-c"
"Architecture": "arm64",
"Os": "linux",
"Size": 294132095,
"VirtualSize": 294132095,
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/b6424b2fe0d7a6a5b10cb3f59f62f50f9da7807d4e764f49eec03d388621f4af/diff:/var/lib/docker/overlay2/197740c66cd677c1b6d1e08d9ba1c982fa8dee2a6ea96ad9bdebf94ece36c8f5/diff:/var/lib/docker/overlay2/1e1189a97a984e9868dd31dd649aa7c36f92d021896d71d5c0959f1cf11441e7/diff:/var/lib/docker/overlay2/05c9e2c74f9406ca7b4980f90655a6a8c8baf7d74669f5f00b4e22c4a43c46c7/diff:/var/lib/docker/overlay2/25a5630bce5b276cae0b30e0fc869a687ac8cf748bf18de2d25ec672406d0e11/diff:/var/lib/docker/overlay2/66afad52b63aabe80da1d70f97313fd053916eae2f71bd7cdda3d7bf3cf94b0f/diff:/var/lib/docker/overlay2/51972cf14a09fee3b9bb2dfa4b6606dcc0e47ddb22933d70e0019347306cdbf3/diff:/var/lib/docker/overlay2/28e655538b408f409aa38a1b73d997c09fc91e7419dae1efbe9882c8ca55f588/diff",
"MergedDir": "/var/lib/docker/overlay2/1ad1f7c2df7e355efc0c6a0cff53ce79519741bebba04bad8dde0ac5920497e6/merged",
"UpperDir": "/var/lib/docker/overlay2/1ad1f7c2df7e355efc0c6a0cff53ce79519741bebba04bad8dde0ac5920497e6/diff",
"WorkDir": "/var/lib/docker/overlay2/1ad1f7c2df7e355efc0c6a0cff53ce79519741bebba04bad8dde0ac5920497e6/work"
"Name": "overlay2"
"RootFS": {
"Type": "layers",
"Layers": [
"sha256:13594e6f72105befed183626c2e1c6d7b31d7fc2c0f7e682d7fb5f2a75e5c4a2",
"sha256:1bb4d946ceef7f5945db4a3ff7f91a8f0b5fe6239aad5d3f0c8bf57f8b740419",
"sha256:5f70bf18a086007016e948b04aed3b82103a36bea41755b6cddfaf10ace3c6ef",
"sha256:c53f5e4695ba3b1fd4ead7d8d9c59f8bae89c750225f5308a933827cae7bbed0",
"sha256:885da28193e4b57e9c54daed0c4f256fecf77d0df42074c4931f2ddf73c6df3a",
"sha256:94e3a0d3cddb22e5891a76ea27a8ed66ab4d175acea8a9178000f299b51a1fe2",
"sha256:aa50ba4cf51d72db2d67c185e049f55e78b607f365ce012219d8ffe5b802e3ca",
"sha256:5fdc734eff9bebc508dae778b6be76e8276c512bd88262d03ea1940792b0bb27",
"sha256:0728cfff109aac5580d49dfc7cbeb59fd1646dc6c46a5c89dd173168a2f0557b"
"Metadata": {
"LastTagTime": "0001-01-01T00:00:00Z"
And this is the information I get from running "docker info":
Client: Docker Engine - Community
Version: 24.0.2
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.10.5
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.18.1
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
Containers: 5
Running: 3
Paused: 0
Stopped: 2
Images: 21
Server Version: 24.0.2
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: active
NodeID: <censored>
Is Manager: false
Node Address: <censored>
Manager Addresses:
<censored>
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 3dce8eb055cbb6872793272b4f20ed16117344f8
runc version: v1.1.7-0-g860f061
init version: de40ad0
Security Options:
seccomp
Profile: builtin
cgroupns
Kernel Version: 6.1.21-v8+
Operating System: Debian GNU/Linux 11 (bullseye)
OSType: linux
Architecture: aarch64
CPUs: 4
Total Memory: 7.629GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: No memory limit support
WARNING: No swap limit support
