Dear commuity
*If you are Experiencing issues with a Pi-hole install that has standard elements
No issue
_[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
- Debian 12 beelink 4gb and SSD 192.168.1.143 secondary hole with ipv6
- Debian 12 lxc proxmox 192.68.1.136 AS primary hole without ipv6
Gravity-Sync working. 136 (Main) is syncing 143 (secondary) evey 15 min, crontab in proxmox lxc
Actual Behaviour: only secondary 143 is filtering the traffic.
fritzbox 192.168.1.1 is DHCP Server.
Condintional forwarding switched to fritzbox
Not yet placed
May I ASK for support
I would like to run 2 piholes for redundancy as one might broke, or proxmox down.
Do you have any nice documention you can recommend.
I would like to usw to use groups and specific roles to avoid claims from family but TV and other stuff do not need to call home.
Thank you for support
Regards
