127.0.0.1#5335, Unbound, PI-Hole help
Hi, I have RPI 4 8GB with RPI OS 64-bit 2023-05-03-raspios-bullseye-arm64.img OS setup with RPI, PI-Hole up and running and configured to block ads, also using PI-Hole for DHCP.
I have unbound installed and configured from crosstalksolutionsDOTcom/the-worlds-greatest-pi-hole-and-unbound-tutorial-2023/
I deselected upstream DNS servers in PI-Hole and enable custom #1 field to 127.0.0.1#5335.
I have no internet access with custom 127.0.0.1#5335 set.
Any suggestions?
What are the outputs of the following commands from the Pi terminal?
dig pi-hole.net @127.0.0.1 -p5335
Sorry for a while reply, figuring out how to get the needed copied info to windows, finally got what you're asking for.
@raspberrypi:~ $ sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	name: "192.168.1.137"
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	forward-addr: 192.168.1.137
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	name: "."
/etc/unbound/unbound.conf.d/pi-hole.conf:verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf:interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf:port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf:do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf:prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf:harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf:edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf:prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf:so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf:private-address: fe80::/10
@raspberrypi:~ $ dig pi-hole.net @127.0.0.1 -p5335
; <<>> DiG 9.16.42-Debian <<>> pi-hole.net @127.0.0.1 -p5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 35191
;pi-hole.net.			IN	A
;; Query time: 0 msec
;; WHEN: Fri Jul 14 21:05:04 CDT 2023
;; MSG SIZE  rcvd: 40
This is your problem. All your unbound queries are being forwarded to this IP (Pi-hole?), instead of unbound functioning as a recursive DNS server.
  1. Edit file /etc/resolvconf.conf and comment out the last line which should then read:
#unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Restart unbound:
sudo service unbound restart
It is now working, thank you.
how do i go on about seeing "dns leak test" that pi hole & unbound is dns server rather my ISP?
thanks a lot :+1:
i used this and shows my isp as my dns server.
edit
this shows my isp as dns server too.
do i have to point my router to 127.0.0.1#5335 rather the pi hole dns ip?
I see that DNS is getting handled by unbound.
OK (answered by localhost#5335)
Since unbound is a recursive resolver running at your home IP, most leak test sites associate the DNS server with your ISP.
