0 Queries blocked
Hi Team,
I’ve setup pihole on a fresh pi a couple of weeks ago, everything worked fine. Today I noticed I’m seeing ads again so I checked the web interface and noticed 0 queries blocked. I also saw a warning "No valid NTP replies received, check server and network connectivity". Did some diagnosis, but everything looked fine. Did a restart of the pi, but to no avail. Router DNS settings also look fine. Any ideas? Debug token below
PiHole should block a lot of queries as it used to do until a couple of days ago (I didn’t change anything in the meantime)
PiHole is not blocking any queries anymore
https://tricorder.pi-hole.net/MGuL3EIT/
A few things I did in the meantime:
  • install updates, reboot pihole - no effect (though the warning is gone)
  • Disabled DHCP on my router and enabled it on pihole - no effect (apart from not being able to ssh into my pi anymore, so I enabled DHCP on the router again)
  • when I run networksetup -getdnsservers Wi-Fi on a client, I get 8.8.8.8 instead of the expected pihole’s ip address
  • When I check active clients, I can see my router 192.168.2.1 stopped using pihole yesterday
  • running nslookup pi.hole gives me
    Server: 8.8.8.8
    Address: 8.8.8.8#53
    ** server can't find pi.hole: NXDOMAIN
