Hello,
I tried to install pihole on my pi but get messages about missing setupVars.conf and have an empty /etc/pihole directory save for the logfile.
I have run the repair a few times but still get the same results of no domains blocked in the admin tool. I saw a similar thread here from a user running on a synology box, his issue was a firewall it seemed, but not sure if that helps me at all.
Below is some commands that folks here had him run with my output in case similar data is helpful. I also ran the debug and uploaded the results with key rt73xdc3im
Any pointers much appreciated.
Thanks
ayb
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l
Last login: Mon Jan 2 15:37:00 2017 from 10.0.0.18
pi@raspberrypi ~ $ ls /lib/modules
4.1.19+ 4.1.19-v7+
pi@raspberrypi ~ $ uname -r
3.12.22+
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l GNU/Linux
pi@raspberrypi ~ $ iptables -L
libkmod: ERROR ../libkmod/libkmod.c:554 kmod_search_moddep: could not open moddep file '/lib/modules/3.12.22+/modules.dep.bin'
iptables v1.4.14: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
pi@raspberrypi ~ $ sudo iptables -L
pi@raspberrypi ~ $ pihole -up
::: Checking for updates...
::: Pi-hole version is v2.10.2
::: Web Admin version is v2.2
::: Everything is up to date!
pi@raspberrypi ~ $ modprobe -V
kmod version 9
pi@raspberrypi ~ $ pihole -v
::: Pi-hole version is v2.10.2 (Latest version is v2.10.2)
::: Web-Admin version is v2.2 (Latest version is v2.2)
pi@raspberrypi ~ $ pihole -g
::: WARNING: /etc/pihole/setupVars.conf missing. Possible installation failure.
::: Please run 'pihole -r', and choose the 'reconfigure' option to reconfigure.
pi@raspberrypi ~ $ pihole -d
::: Beginning Pi-hole debug at Mon Jan 2 16:29:33 UTC 2017!
::: This process collects information from your Pi-hole, and optionally uploads
::: it to a unique and random directory on tricorder.pi-hole.net.
::: NOTE: All log files auto-delete after 24 hours and ONLY the Pi-hole developers
::: can access your data via the given token. We have taken these extra steps to
::: secure your data and will work to further reduce any personal information gathered.
::: Please read and note any issues, and follow any directions advised during this process.
/opt/pihole/piholeDebug.sh: line 50: /etc/pihole/setupVars.conf: No such file or directory
::: Detecting Installed Package Versions:
::: Pi-hole: v2.10.2
::: WebUI: v2.2
::: lighttpd/1.4.31
::: /opt/pihole/piholeDebug.sh: line 123: php: command not found
::: Detecting existence of /etc/pihole/setupVars.conf:
::: /etc/pihole/setupVars.conf not found! and could not be sourced
::: Detecting installed OS Distribution
::: Checking processor variety
::: IP Address Information
::: IPv6 addresses located
::: Pinging default IPv6 gateway: unknown host
Gateway Responded.
::: Pinging Internet via IPv6: socket: Address family not supported by protocol
Query responded.
::: IPv4 addresses located
::: Pinging default IPv4 gateway: Gateway responded.
::: Pinging Internet via IPv4: Query responded.
::: Daemon Process Information
::: Checking http port for lighttpd listener.
::: Failure: IPv6 Port not in use
::: Correctly configured.
::: Checking domain port for dnsmasq listener.
::: Processes Check
::: Logging status of lighttpd and dnsmasq...
/opt/pihole/piholeDebug.sh: line 307: systemctl: command not found
::: Resolver Functions Check
::: Checking for necessary lighttpd files.
::: Detecting existence of /etc/lighttpd/lighttpd.conf:
::: File exists
::: Detecting existence of /var/log/lighttpd/error.log:
::: File exists
::: Detecting existence of /etc/dnsmasq.conf:
::: File exists
::: Detecting existence of /etc/dnsmasq.d/01-pihole.conf:
::: File exists
::: Detecting existence of /etc/pihole/whitelist.txt:
::: /etc/pihole/whitelist.txt not found!
::: Detecting existence of /etc/pihole/blacklist.txt:
::: /etc/pihole/blacklist.txt not found!
::: Detecting existence of /etc/pihole/adlists.list:
::: /etc/pihole/adlists.list not found!
::: Analyzing gravity.list
wc: /etc/pihole/gravity.list: No such file or directory
::: Warning: No gravity.list file found!
::: --= User Action Required =--
::: Try loading a site that you are having trouble with now from a client web browser..
::: (Press CTRL+C to finish logging.)
::: pihole.log
::: Logging will automatically teminate in 60 seconds
::: Finshed debugging!.
::: The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
::: Would you like to upload the log? [y/N] y
::: Your debug token is : rt73xdc3im
::: Please contact the Pi-hole team with your token for assistance.
::: Thank you.
::: A local copy of the Debug log can be found at : /var/log/pihole_debug.log
pi@raspberrypi ~ $ ls -l /etc/pihole/
total 4
-rw-r--r-- 1 root root 672 Dec 31 16:03 install.log
pi@raspberrypi ~ $
