Enter to speedtest.net and look that ads are blocked.
0% of ads are blocked.
https://tricorder.pi-hole.net/3t6yia2zlo
Creating this topic due can't find resolution...
There is an unexpected behavior in V5.0 when the privacy level is set to 4, as in your case. This results in no blocking. The solution is to set your privacy level to 3 or lower.
[2020-06-13 00:45:21.398 508] Notice: Increasing privacy level from 0 to 4
[2020-06-13 00:45:21.398 508] PRIVACYLEVEL: Set to 4
https://github.com/pi-hole/FTL/issues/755
all network devices are “Device does not use Pi-hole"
This is a separate issue. From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup pi.hole 192.168.1.83
Hm, I understood wrong that privacy level and set level 0 during installation... Thanks for help. As I lost half of day trying to find the problem.
