Update: I installed it on my test machine, it's not reliable, it worked only with windows. However in Android it failed to route the traffic. Hope this helps
So by googling you meant that it didn't work at first and you had to troubleshoot?
Mind sharing what went wrong and how you fixed it?
EDIT: I've followed that tutorial exactly, (except changing the port from 1194 to mine) my openVPN works but my stunnel logs show no activity. I'm testing this on my windows machine.
Here's my openVPN log if it helps:
Wed May 31 14:08:45 2017 OpenVPN 2.4.2 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on May 11 2017
Wed May 31 14:08:45 2017 Windows version 6.2 (Windows 8 or greater) 64bit
Wed May 31 14:08:45 2017 library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.10
Enter Management Password:
Wed May 31 14:08:45 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed May 31 14:08:45 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]publicIP:4096
Wed May 31 14:08:45 2017 Attempting to establish TCP connection with [AF_INET]publicIP:4096 [nonblock]
Wed May 31 14:08:46 2017 TCP connection established with [AF_INET]publicIP:4096
Wed May 31 14:08:46 2017 TCP_CLIENT link local: (not bound)
Wed May 31 14:08:46 2017 TCP_CLIENT link remote: [AF_INET]publicIP:4096
Wed May 31 14:08:48 2017 [server] Peer Connection Initiated with [AF_INET]publicIP:4096
Wed May 31 14:08:50 2017 open_tun
Wed May 31 14:08:50 2017 TAP-WIN32 device [Ethernet 2] opened: \.\Global{0883BC25-95CD-4121-A087-7D4EFAD22A18}.tap
Wed May 31 14:08:50 2017 Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.2/255.255.255.0 [SUCCEEDED]
Wed May 31 14:08:50 2017 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.2/255.255.255.0 on interface {0883BC25-95CD-4121-A087-7D4EFAD22A18} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed May 31 14:08:50 2017 Successful ARP Flush on interface [9] {0883BC25-95CD-4121-A087-7D4EFAD22A18}
Wed May 31 14:08:50 2017 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Wed May 31 14:08:55 2017 Initialization Sequence Completed
Stunnel log (no activity):
2017.05.31 14:06:26 LOG5[main]: stunnel 5.41 on x86-pc-msvc-1500 platform
2017.05.31 14:06:26 LOG5[main]: Compiled/running with OpenSSL 1.0.2k-fips 26 Jan 2017
2017.05.31 14:06:26 LOG5[main]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,FIPS,OCSP,PSK,SNI
2017.05.31 14:06:26 LOG5[main]: Reading configuration from file stunnel.conf
2017.05.31 14:06:26 LOG5[main]: UTF-8 byte order mark detected
2017.05.31 14:06:26 LOG5[main]: FIPS mode disabled
2017.05.31 14:06:26 LOG4[main]: Service [openvpn] needs authentication to prevent MITM attacks
2017.05.31 14:06:26 LOG5[main]: Configuration successful
2017.05.31 14:07:43 LOG5[main]: Reading configuration from file stunnel.conf
2017.05.31 14:07:43 LOG5[main]: UTF-8 byte order mark detected
2017.05.31 14:07:43 LOG5[main]: FIPS mode disabled
2017.05.31 14:07:43 LOG4[main]: Service [openvpn] needs authentication to prevent MITM attacks
2017.05.31 14:07:43 LOG5[main]: Configuration successful
2017.05.31 14:07:49 LOG5[main]: Reading configuration from file stunnel.conf
2017.05.31 14:07:49 LOG5[main]: UTF-8 byte order mark detected
2017.05.31 14:07:49 LOG5[main]: FIPS mode disabled
2017.05.31 14:07:49 LOG4[main]: Service [openvpn] needs authentication to prevent MITM attacks
2017.05.31 14:07:49 LOG5[main]: Configuration successful
That warning from stunnel is common I believe, it's also in the hour long tutorial and it worked fine for that guy.
Connectivity wise, the openVPN works perfectly fine, both locally and remotely.
My problem is, looking at the youtube tutorial, each time they connect to the VPN the stunnel log would update itself indicating something is happening. In my case, the stunnel logs shows no activity as if the openVPN is not being routed through stunnel.
I think it has something to do with my ports? It is either the stunnel.conf on the raspiberry pi or windows machine that has a problem...but then, I'm not sure.
@Anudeep I've been watching and reading other tutorials on the internet, still couldn't get it working. I guess I'm a little confused on the accept and connect part of the config...Could you post your config? I want to know what worked for you.
Following the tutorial solved my problem. I was using the wrong ports all along.
So now my openVPN and stunnel works properly. All except one thing: My samba shares.
I have a samba share running on my local network, I am able to log in to my home's router remotely which means my traffic is being routed correctly. It works if I access the samba shares from my android phone via the network browser app but not through the windows network tab.
This is beyond my understanding, I've searched through the openVPN forums and I found nothing useful there.
I tried disabling all firewalls and antiviruses, and kept refreshing the network tab hopefully my samba share would show up, but nothing.
I need help on this, do you know how to get the samba shares working remotely ?
EDIT: I am even able to VNC to my raspberry pi remotely ! Samba not working remotely is weird..
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 1099/smbd
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 1099/smbd
tcp6 0 0 :::139 :::* LISTEN 1099/smbd
tcp6 0 0 :::445 :::* LISTEN
Samba version 4.2.14-Debian
PID Username Group Machine Protocol Version
Service pid machine Connected at
No locked files
No more pihole, sometimes it blocks some of the websites I use and in the long run, this gets annoying quick so I uninstalled it, I like the idea of the pihole though..
