[installation runs through completely]
_[root@DeLatitude:~# curl -sSL https://install.pi-hole.net | bash
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 2 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[i] Checking for dialog (will be installed)
[✓] Checking for debconf
[i] Checking for dhcpcd5 (will be installed)
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
root@DeLatitude:~#
]_
[cannot get a debug token from something that cannot install]
