Wildcard subdomain does not get resolved by PiHole
I have registered a wildcard subdomain with my registry. The resolution works fine outside of my home. Behind PiHole all clients cannot resolve any subdomain matching the wildcard.
  • Operating System (Family and Version): raspbian 13
  • Hardware raspberry pi 4B
  • Docker compose file or Docker run command: docker compose
  • Docker engine version 29.9.0
I would expect that the IP address is resolved correctly.
I defined custom dns entries in PiHole for my important subdomains. I would like to not be needing this.
Resolution is tested on Android, Macos, iOS and always returns cannot resolve host.
Replace this text with the debug token provided from running pihole -d
https://tricorder.pi-hole.net/pNLuzC6S/
Please post the output of
docker exec pihole pihole-FTL --config dns.domain
My guess is that dns.domain.name is set to your registered domain. With dns.domain.local = true (the default), Pi-hole then answers every name in that domain itself and never asks upstream, so only the names you added as custom DNS records resolve. If that's the case, either set dns.domain.name back to a purely local name, e.g., lan, or set dns.domain.local = false so the other names are forwarded upstream again.
Thanks for the quick response!
This is the output
$ docker exec pihole pihole-FTL --config dns.domain
dns.domainNeeded = true
dns.domain.name = pi.hole
What would be the downside of having dns.domain.local set to false?
Then my guess was wrong, dns.domain is not the cause and you should leave it as it is. With dns.domain.local = false, unanswered queries for *.pi.hole would go to your upstream servers, which helps nothing here.
Please run, with one of the wildcard names that fails:
docker exec pihole dig foo.example.com
docker exec pihole dig foo.example.com @1.1.1.1
and post both outputs, with your domain in place of example.com. Also tell me whether the wildcard points to a private address such as 192.168.x.x: several routers and upstream resolvers drop such answers as DNS rebinding.
Actually your hint helped a lot. I used my real local domain from my router and it works now!
dns.domain.name = fritz.box
