rdx
August 9, 2020, 6:00pm
1
2 piholes using same blocklists but the number of blocked domains is way off.
A with lesser domains
https://tricorder.pi-hole.net/6465swsv9l
Result of pihole -g
[i] Number of gravity domains: 185772 (156885 unique domains)
B with higher number of domains
https://tricorder.pi-hole.net/pdezm2grp0
Result of pihole -g
[i] Number of gravity domains: 212625 (183673 unique domains)
jfb
August 9, 2020, 6:07pm
2
Please post the complete output of pihole -g
from each of the two Pi-holes. You can paste the output into a reply and format the text blocks as "pre-formatted text" using the </> icon.
rdx
August 10, 2020, 3:14am
3
@jfb Sorry i ran into some issues with my OS and had to reinstall, this time it numbers match, but if someone wants to see can check the debug.
jfb
August 10, 2020, 4:09am
4
The debug logs don't show that detail. But, problem solved.
