I have a v4 and v5 server running, both have the exact same blocklists (copy/paste) and are updated both on the same time (5 mins ago).
v4 has 1,482,938 domains on blocklist
v5 has 1,210,598 domains on blocklist
How is that possible?
The algorithm to remove invalid domains from adlists has been improved.
Even when v4 shows more domains they might have not worked or created false-positives (overblocking)
Thanks for the fast and clear answer!
The output of pihole -g
will show details for each blocklist and can help you eliminate incorrectly formatted lists.
