If I want to whitelist Every sub behind lets say spotify.com would be great i i could type in
*.spotify.com (this methode is used in many other adblockers) and it would just block every sub
- 1
- 2
- 3
- 4
- 5
0 voters
0 voters
If I'm not mistaken, isn't this already a feature?
I just did it didn't work
Oh yeah, I just checked, doesn't work. I swear I've seen that in a changelog before. Would be a great feature
yeah makes blocking and whitelisting so much easyer
Found it, you can wildcard a domain from command line
pihole -wild (domain to wildcard)
For example:
pihole -wild googleadservices.com
Or you can do it from the interface, type in the domain and instead of just pressing enter, press 'Add (Wildcard)'
No from the web interface you go to the blacklist (or whitelist) and type in googleadservices.com
then press the 'Add (wildcard); button
Well if i try it in the commandline it still doesn't work
What did you type in?
sudo pihole -wild googleadservices.com
it gave me out that:
sudo: unable to resolve host pihole
::: Adding googleadservices.com to wildcard blacklist...
::: Neutrino emissions detected...
::: Custom adList file detected. Reading... done!
::: Using cached Event Horizon list...
::: 116204 unique domains trapped in the event horizon.
::: Adding adlist sources to the whitelist... done!
::: Whitelisting 8 domains... done!
::: Nothing to blacklist!
::: Wildcard blocked domain: 1
::: Formatting domains into a HOSTS file... done!
::: Cleaning up un-needed files... done!
::: Refresh lists in dnsmasq... done!
::: DNS service is running
::: Pi-hole blocking is Enabled
quiet strange tho?
That worked. Btw, you haven't added 'pihole' to your /etc/hosts
change 127.0.0 raspberry to
127.0.0 pihole
and gooeladservices is already blocked, also remember to clear your DNS cache
ipconfig /flushdns (Windows)
and chrome://net-internals -> DNS -> Clear resolver cache on Chrome.
If you mean that you want to blacklist, then yes. It is already there
that is perfectly fine, but I agree that the wording could be improved on this.
I want to whitelist spotify in case they change a sub
So i know in the blacklisting its there but not in the whitelistimg
@DL6ER is it possible to enter *.spotify.com for the future?
Would be great if i get into som errors again😜
Currently we don't support wildcard whitelisting. We are still looking for a solution.
Okay great thanks
( why is there an maximum of reply ?)
There's some default spam-prevention limits built into Discourse. I hope they aren't limiting you?
they are i can't post with my first account for an other 7 houers that im working on pihole
