Acessing to octopi by either whitelisting or disabling Pihole
I cannot access some pages like "octopi.local" or even thru ip adress "octopi/xxx.xxx.x.xxx". I tried whitelisting both on webpage and pihole.
Cleared cache for web browsed
Cleared dns in cmd
Cleared dns in
Tried also disabling pihole on web page, still got denied.
https://tricorder.pi-hole.net/kuvemgv5rd
jfb
October 19, 2019, 12:37pm
2
Is octopi a web server? It is the locally mapped name of your Pi, but does it have the capability to serve web pages?
If you are trying to load your Pi-Hole admin web page, the address is http://pi.hole/admin .
-rw-r--r-- 1 root root 136 Oct 19 12:59 /etc/pihole/local.list
192.168.2.173 octopi
192.168.2.173 pi.hole
I don't have any problem accessing Pihole. My issue is with octoprint, which i need to access thru a web page. Octopi is part of octoprint, where i can access my 3d printed thru a local network.
Blockquote -rw-r--r-- 1 root root 136 Oct 19 12:59 /etc/pihole/local.list
I am not quite sure what that says to me or what i should do with it. When i try "/etc/pihole/local.list" I get permission denied
this is atleat what it shows to me:
Got any links to where i can see how to change the octoprint ports? as i am not sure how to do that.
I am still lost, I did the following. but what now, how do i acess it, do i need to change anything with my network ?
sudo nano /etc/haproxy/haproxy.cfg
changed too:
frontend public
bind *:8888
bind 0.0.0.0:443 ssl crt /etc/ssl/snakeoil.pem
option forwardfor except 127.0.0.1
Saved it
sudo /etc/init.d/haproxy restart
sudo reboot
Thank you for patience and help to someone with no knowledge!
I made step by step process for other people that know little about this.
You need to edit haproxy.cfg
Save & reboot
open Octoprint through http attatched with :8888
Instead of http://octopi.local
Now http://octopi.local:8888
system
Closed
November 17, 2019, 1:04pm
10
