I've switched from lighttpd to nginx and now when I click on Whitelist link ou Blacklist and I have an error.
Same when I try to whitelist or blacklist a domain.
Display the list and/or add the domain to the list
Error saying:
Failure! Something went wrong, see output below:
nginx is not supported as a Pi-hole web interface. There is an unsupported community guide you can try, or you can run nginx and lighttpd on different ports.
Thank you jfb for your input. That page didn't really help to understand the underlying problem.
The whole website works without a problem, only the Whitelist/BlackList menu on the left.
How/where can I track the error the loading of that page produces ?
That will help me understand how I can fix it.
For the record, the problem was in the nginx site parameters: the php files not in the root dir weren't accessible (404 error). And Whitelist/Blacklist are located in the scripts/pi-hole/php dir unlike most of the files.
