I expected that when I added a whitelist (tried a few different ways), Regex and normal, it would allow me to access the domain.
Similarly, I tried to simply "Disable" for 5 minutes - and still nothing.
I am completely unable to access the domain Twilio.ivdev.ru whatsoever... unless I tether my computer to my phone - in which case, it instantly works... so I know it's a PiHole issue.
-I don't believe this is needed/relevant for this issue, it's likely user error
jfb
September 21, 2020, 3:41pm
2
Please post the token generated by
Tools > Generate Debug Log
This will show us your groups and blocking assignments.
Sorry about that, didn't think it was relevant as I assumed user error:
Debug log made private by moderator
jfb
September 21, 2020, 5:16pm
5
From the Pi terminal, what is the output of the following command:
nslookup twilio.ivdev.ru 127.0.0.1
From the terminal or command prompt of a connected client from which you cannot reach this domain (and not via ssh to the Pi), what are the outputs of these commands:
nslookup twilio.ivdev.ru 192.168.1.44
And then, from the Pi terminal again, the output of the following
grep twilio.ivdev.ru /var/log/pihole.log | tail -n20
**From the Pi terminal**
**From my Mac connected to the network the pi runs with:**
JLMBP:~ jlevi1$ nslookup twilio.ivdev.ru
JLMBP:~ jlevi1$ nslookup twilio.ivdev.ru 192.168.1.44
**From the Pi Again**
pi@raspberrypi : ~ $ grep twilio.ivdev.ru /var/log/pihole.log | tail -n20
Sep 24 10:55:49 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 10:55:54 dnsmasq[537]: query[A] twilio.ivdev.ru from 192.168.1.34
Sep 24 10:55:54 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.4.4
Sep 24 10:55:54 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:00:17 dnsmasq[537]: query[A] twilio.ivdev.ru from 127.0.0.1
Sep 24 11:00:17 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:00:22 dnsmasq[537]: query[A] twilio.ivdev.ru from 127.0.0.1
Sep 24 11:00:22 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.4.4
Sep 24 11:00:22 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:00:27 dnsmasq[537]: query[A] twilio.ivdev.ru from 127.0.0.1
Sep 24 11:00:27 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.4.4
Sep 24 11:00:27 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:01:31 dnsmasq[537]: query[A] twilio.ivdev.ru from 192.168.1.34
Sep 24 11:01:31 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:01:36 dnsmasq[537]: query[A] twilio.ivdev.ru from 192.168.1.34
Sep 24 11:01:36 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.4.4
Sep 24 11:01:36 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
Sep 24 11:01:41 dnsmasq[537]: query[A] twilio.ivdev.ru from 192.168.1.34
Sep 24 11:01:41 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.4.4
Sep 24 11:01:41 dnsmasq[537]: forwarded twilio.ivdev.ru to 8.8.8.8
system
Closed
October 15, 2020, 8:12am
7
