Hi there,
I recently changed my internal network IP due to a new ISP with the same internal IP.
I performed pihole -r and configured pi-hole.
However, next to pi-hole I also have DNScrypt installed, but I am not sure if this is working as intended.
If I look at etc/resolve.conf I see:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 8.8.8.8
nameserver 8.8.8.8
In pihole I have set ip as Upstream DNS Servers: 127.0.0.1#54 which is the port DNScrypt is at.
What should be in resolve.conf? Am I doing this correct?
Below output of dig:
; <<>> DiG 9.10.3-P4-Raspbian <<>> debug.opendns.com txt
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11744
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;debug.opendns.com. IN TXT
;; AUTHORITY SECTION:
opendns.com. 49 IN SOA auth1.opendns.com. noc.opendns.com. 1562667043 16384 2048 1048576 2560
;; Query time: 11 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Tue Jul 09 12:51:45 CEST 2019
;; MSG SIZE rcvd: 92
Thank you in advance.
Cheers,
