There is nothing you need to worry about here. You’re iPhone just uses mDNS service discovery to find AirPlay, AirPrint and other Bonjour services in your network.
Should CGNAT reserved addresses 100.64.0.0/10 be added to that list.
No, why? You won't use them on your local network. And they are not specified as private IPs.
I wouldnt know for sure.
Luckily I dont have CGNAT ![]()
I know its nothing to worry about, I just don't get why its only my iPhone and none of the others in the house, also it only started a few weeks ago, I do have airplay compatible devices, yes
wait a minute, when you open certain apps now it predicts you want to airplay and comes up on the dynamic island, maybe its that
dosn't NAT just do this anyway
private address don't do anything other than communicate with the router and LAN devices
if they got upstream they would be invalid as the address is not available to the public
anyway not as many today, but I bet its what I mentioned above
Because your iPhone uses the Apple Bonjour protocol, and this form of DNS Discovery Service is used by Apple in their OS's. The OS uses this to discover local services.
Using Pi-hole as an example, it uses below directive to prevent those local PTR queries (reverse lookups) from flooding the upstream DNS servers with undesired queries that they cant answer anyway:
$ cat /etc/dnsmasq.d/01-pihole.conf
bogus-priv
$ man dnsmasq
-b, --bogus-priv
Bogus private reverse lookups. All reverse lookups for
private IP ranges (ie 192.168.x.x, etc) which are not
found in /etc/hosts or the DHCP leases file are an‐
swered with "no such domain" rather than being for‐
warded upstream. The set of prefixes affected is the
list given in RFC6303, for IPv4 and IPv6.
Have a read on that blackhole link:
The other way around (a forward lookup), if Pi-hole is doing DHCP, it applies below directive to prevent lookups with the local domain being forwarded upstream:
$ cat /etc/dnsmasq.d/02-pihole-dhcp.conf
local=/home.dehakkelaar.nl/
$ man dnsmasq
-S, --local, --server=[/[<domain>]/[do‐
main/]][<ipaddr>[#<port>][@<source-ip>|<interface>[#<port>]]
Specify IP address of upstream servers directly.
Also permitted is a -S flag which gives a domain but
no IP address; this tells dnsmasq that a domain is lo‐
cal and it may answer queries from /etc/hosts or DHCP
but should never forward queries on that domain to any
upstream servers. --local is a synonym for --server
to make configuration files clearer in this case.
Most routers do the same.
A while back the box. TLD became available publicly.
That caused problems for Fritzbox routers that have the fritz.box domain hardcoded into their routers.
Clients that were not using Fritzbox for DNS ended up on public servers bc some crooks registered fritz.box and created DNS records to redirect traffic.
long messages, but still nobody seems to agree or disagree with what I think it could be
it seems to have stopped suggesting airplay mirroring, and it think that's what stopped these requests, but further investigation is required, they were frequent
I will leave it here, and follow up if I have anymore information
or I might forget
I thought you wanted to learn a bit so you yourself could figure it out ![]()
I do have two iPads here but not those queries.
They are not used for airply though.
I suspect an app thats depending on service discovery is the culprit.
Some more info about above dns-sd query:
EDIT: I changed the link a bit!
They have come back and I have not used airplay mirroring, so this does seem the case
I gave that link a quick read
still no idea why its just my iPhone not anyone else's, we have 2 iPhone here all the time, and a lot of old ones that are used for beta testing, its just my main iPhone that does this
And as I setup both them iPhones, only one is mine, but I set them both up, there wireless setup is exactly the same
I wish I could find the destination intention as pi-hole seems to return nothing
NXDOAMIN, so why does the device not give up
so what uses DNS-SD?
lb._dns-sd._udp.0.0.168.192.in-addr.arpa
lb._dns-sd._udp.cn-lan
lb._dns-sd._udp.6.0.0.192.in-addr.arpa
lb._dns-sd._udp.2.0.0.192.in-addr.arpa
does it think there is a device at 192.0.0.2 and 192.0.0.6 there invalid ip address anyway
the subnet is 255.255.0.0 not 255.0.0.0
192.168.0.0 is the only valid request being sent. but still gets nothing returned
I just made them hidden, so real domains can be on the top list, instead of these
